US285126
Jul 18, 2020Tutor
CM1150V Modem, RBR50 Orbi and MOCA network
I have a CM1150V modem connected to an Orbi RBR50 Router. Trying to get a MOCA network setup. I'm using the TIVO Bridge Plus Adapter and have a POE filter attached between wall and TIVO Bridge Plus...
US285126
Jul 18, 2020Tutor
Thanks for your response. Initially I did not have a POE filter at all and was still having the issue. I installed it thinking it might help. (I was honestly grasping at straws.) I took your suggestion and uninstalled it. Still nothing.
Shouldn't I be able to see the MOCA adapter on the Orbi Attached devices?
US285126
Jul 18, 2020Tutor
Follow-up question... Tivo says "Have your router/modem manufacturer set the MoCA output to 2.0 as a standard."
How is this done? Is this already the default? Can't find a place in the Advanced Setup to configure anything related to MOCA.
