jhunter58
Sep 03, 2023Aspirant
Coax vs Fiber connection
I have a Netgear Orbi RBK23-100NAS Mesh Wireless Router, purchased new in March of 2020. The Firmware Version is: V2.7.4.24.
I am changing internet providers very soon from a coax broadband service...
- Sep 03, 2023
Yes. Have the ISP help you get the RBR connected with there equipement.
michaelkenward
Sep 04, 2023Guru - Experienced User
jhunter58 wrote:
My question is, will my router sync up with the fiber connection, or do I need to have some type of Modem set up like I have with my current coaxial service provider in order to continue with my wireless connection throughout the home?
It should be a simple case of plugging your RBK into the ONT.
But it may not be a simple plug and pray process. You'll want to hang on to the existing SSID and passwords for the wifi, so try to avoid having to reset the router. That is often recommended when changing a modem and/or ISP.
If it doesn't all come together when you restart the network, you could try running the Internet setup wizard on the Orbi router.
