thwat
Mar 18, 2020Tutor
Code 404 and no internet signal with Orbi RBK 50
Hello there, I just got a netgear orbi RBK50 but I am having some issues: 1. When trying to connect to some sites it does not work and gives me a 404 error. I tried to connect with the wifi e...
Mar 18, 2020Guru - Experienced User
Power OFF the ISP modem and RBR for 30 seconds then back on.
Has a factory reset and setup from scratch been performed since last FW update? YOu might do this and walk thru the setup wizard with a web browser connected to the RBRs web page at orbilogin.com
thwat wrote:Hello there,
1. When trying to connect to some sites it does not work and gives me a 404 error. I tried to connect with the wifi emitted by the modem and the site works.
2.On my mobile phone it says that the wifi does not have internet but I am able to use it with most common tasks. Some things do not work such as the google play store (downloading)
3.I believe that it is connected to the first two but I am also having issues with connecting to some apps on my laptop so i am unable to login.
if you might know an answer I'd ne happy to hear it.
Thanks.
thwat
Mar 18, 2020Tutor
I'm a bit lost with what you said but you want me to reboot my router and go through the setup once again?
- thwatMar 18, 2020Tutor
But the orbi is brand new
- tomschmidtMar 18, 2020Virtuoso
thwat, did you enable Armor and/or Disney Circle when you setup the router? If so, they could be blocking some of the web sites you are trying to access, thus giving the "404" error. If you enabled them, please disable them and try the sites again that are giving you issues. If they are the cause of the errors, then I suggest posting on the community forum in the sections for Armor and/or Circle.
I wil try
- FURRYe38Mar 18, 2020Guru - Experienced User
Try the reboot of the RBR first and power OFF the ISP Modem for 30 seconds then back ON. If the RBR doesn't get connected. Reset the RBR and walk thru the setup wizard.
I will do it this evening because people are using the network
