thwat
Mar 18, 2020Tutor
Code 404 and no internet signal with Orbi RBK 50
Hello there, I just got a netgear orbi RBK50 but I am having some issues: 1. When trying to connect to some sites it does not work and gives me a 404 error. I tried to connect with the wifi e...
tomschmidt
Mar 18, 2020Virtuoso
thwat, did you enable Armor and/or Disney Circle when you setup the router? If so, they could be blocking some of the web sites you are trying to access, thus giving the "404" error. If you enabled them, please disable them and try the sites again that are giving you issues. If they are the cause of the errors, then I suggest posting on the community forum in the sections for Armor and/or Circle.
thwat
Mar 18, 2020Tutor
I wil try
