Ammashraf
Apr 04, 2020Follower
Combine orbi systems
Hi everyone, I have Orbi RBK50 system and its great, but I’d like to expand the system to every corner of my house, thus I’m wondering is it possible to add another RBK50 to combine with my existing ...
Retired_Member
Apr 04, 2020
Ammashraf wrote:
Hi everyone,
I have Orbi RBK50 system and its great, but I’d like to expand the system to every corner of my house, thus I’m wondering is it possible to add another RBK50 to combine with my existing system? Can the orbi router be one of the satellites? Thank you
You can add more sats...but the orbi router is a router never a sat
from the NG search tool:
https://community.netgear.com/t5/Orbi/Multiple-orbi-routers-in-same-house/td-p/1754104
ekhalil
Apr 04, 2020Master
As Retired_Member mentioned, but -if you have to- you can also use the RBR50 as an AP if you connect it wired t the existing RBR50 and set it to AP mode and use different radio channels than the existing system.
Of course, the best solution is to have only one router and expand with satellites.
