CR4
Nov 03, 2023Guide
Combining several ‘sets’ of Orbi routers and satellites
I am currently using an RBR 20 as an access point and RBS 20 as a satellite. In order to extend my network, I am looking at buying some more 20s or 50s. These are widely available used, as sets conta...
- Nov 04, 2023
CR4 wrote:
... but can’t use it as a wireless access point on the same network?Yes. But see the rest of my first answer.
Looks like that would be a good way of creating a messy network. The choice is yours.
michaelkenward
Nov 04, 2023Guru - Experienced User
CR4 wrote:
Is it possible to add (for example) an RBR 50 as an access point and a couple of RBS 50 satellites to my existing network, if I have the same SSID throughout?
Having the same SSID will not create a single Mesh network.
Why not leave the RBR50 out of the network and add the RBS50s as extra satellites?
One thing you can't do is to use the RBR50 as a satellite.
- CR4Nov 04, 2023GuideThx for the reply.
I know that RBR50 can’t be used as a satellite, but can’t use it as a wireless access point on the same network?
Seems a shame not to be able to use it- michaelkenwardNov 04, 2023Guru - Experienced User
