CrimpOn
Feb 16, 2018Guru - Experienced User
Command to Log DHCP ?
In the past, the ORBI log included every time a DHCP address was issued by the router. I had noticed that some devices seemed to be issued DHCP addresses OFTEN (like, every 5 minutes). The log no l...
BobDuke
Feb 17, 2018Apprentice
DHCP logging is working by default for me. See attached image. 2.1.2.18
CrimpOn
Feb 18, 2018Guru - Experienced User
Hmmmm. After many (many) days of not seeing any DHCP activity in the log, there were some this morning (Sunday). I will continue to look at logs to see when devices are doing DHCP. I don't see anything in the documentation about how long ORBI DHCP leases are for. If I remember correctly, devices ask to renew their lease when half of the lease time has expired. Could ORBI be issuing leases good for weeks?
t_k_Aprentice was correct. The text stream is somewhat of a challenge to read through. I have Wireshark, and it would be easier to use. My linux days are long past, and I'm not exactly certain how to dump to a pcap file and then transfer the file to my Windows machine.
