keylargo
Mar 22, 2020Aspirant
comparing different models
I'm trying to understand the difference between the Orbi models. What's the difference between the RBK52W and the RBK23W. And then how do those compare with the RBK43S (and what's the difference be...
Mar 22, 2020Guru - Experienced User
this table goes over a lot of the different systems.
keylargo
Thank you for the response. But I'm still unclear on the difference between the RBK52, the RBK23, and the RBK43.
- FURRYe38Mar 22, 2020Guru - Experienced User
The only big different between the 50 series and other series is the wifi back haul connection rates, 50 series use 1733Mpbs while all th rest use 866Mpbs.
keylargo wrote:Thank you for the response. But I'm still unclear on the difference between the RBK52, the RBK23, and the RBK43.
- keylargoMar 22, 2020Aspirant
Do you know the difference betwen the 23 and the 43?
There the same in wifi connection rates.
You can download and compare the data sheets between the 20 and 40 series to see if there maybe other differences. Items like memory or CPU maybe a slight difference is all.
