NetgearNetowkri
Jun 04, 2020Tutor
Comparing Modem/Routers Looking to upgrade
Currently, I'm using a Netgear CM1000 Modem with a Nighthawk Router for my home internet system (working with XFinity Internet). I'm thinking of upgrading it to Orbi AC2200. I'm finding it difficult to compare the two systems head to head to be sure that if I make the investment in Orbi AC2200, I'm actualy fullfilling my quest to upgrade my system. Can anyone tell me if I'll be getting greater and further Wifi output with the Orbi? Likley I'd keep the Nighthawk Router and just plug it into the Orbi for an additional Network. Any Suggestions you may have would be most helpful. THANKS!!
What is the model # of your NG router?
You would be best to keep the CM1000 modem and install a Orbi RBK system rather then a CBK40 system.
https://community.netgear.com/t5/Orbi/Find-Your-Orbi-With-the-NEW-Orbi-Product-Selector/m-p/1907267/highlight/true#M91216
https://www.netgear.com/orbi/default.aspx
https://www.netgear.com/orbi/wifi-systems.aspxThanks so much for your response. I'm in the process of reviewing and absorbing it all. In the mean time, I'm responding to answer your question as to what Router I'm using:
Nighthawk AC3200 Tri-Band WiFi Router
Model: R8000
Thanks again for your information!!
FURRYe38 is right on your modem.
How large is your home?
The R8000 is triband. So is the orbi but one of the bands with orbi is reseverd just for the backhaul so isn't something the end user can access and use.
If you're home isn't to large, the R8000 has the options to use both 5ghz bands so might have better coverage/speeds with its usable triband setup.
But if you're home is large enough, the added coverage from the orbi satellites might be better.
so again, a lot depends on your home size and usage.
