Amokura
Jun 09, 2021Aspirant
Compatability with Hitron Router
Can anyone help with whether the RBR50 system will work if connected to a Virgin Media Hitron router? Thanks.
Jun 09, 2021Guru - Experienced User
Will work if you configure one of the following:
Your ISP Modem already has a built in router and wifi. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
