nebula_osx's avatar
nebula_osx
Compatibilità Orbi Voice
Salve. Sono titolare di una linea FTTH Vodafone. Usando già da qualche tempo un router Mikrotik come principale e volendo rimuovere la vodafone station, volevo sapere se il Netgear Orbi Voice può essere collegato al router mikrotik o se necessita obbligatoriamente di un router della serie Orbi.
Grazie in anticipo per la risposta
    • nebula_osx's avatar
      nebula_osx
      ok thank you but, if I don't have any wifi in my house (because my mikrotik router is just a non-wifi router) can I use orbi voice to create a wifi point (like an access point, connecting orbi voice and mikrotik with eth lan cable) or Do I need mandatorily a wifi to extend ?
      • plemans's avatar
        I've got a RBS40V and couldn't find anywhere that it has the options to run AP mode. I also couldn't find it in the manual. So you'll need some type of wireless AP for the RBS40V to run off for extender mode.
