Crusader87's avatar
Crusader87
Compatibility among Orbi devices
There are so many different Orbi devices.
Are all the devices compatible with each other?
I have a RBK50 can i only extend it with a RBK50 satellite?
  • You can use any RBS or RBW satellites with a RBR## series router. You can't however use a RBR## as a satellite. They can only be the main base router or AP.
1 Reply
  • FURRYe38's avatar
