CarlM1975
Feb 01, 2022Initiate
Compatibility of satellites with Orbi RBR20 Router
Hi I have a RBR20 Router and 2 RBS20 satellites, I want to purchase another satellite but Im having difficulty finding one anywhere. Can I buy and use another satellite, for example RBS50? Does ...
Feb 01, 2022Guru - Experienced User
Compatible satellites:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
You can also use the EX7500, EX7700, EX8000 but they don't "integrate" with the system but function as their own mesh.
- CarlM1975Feb 02, 2022Initiate
Thanks very much, this is extremely useful
- gupshupJul 30, 2022AspirantThanks for the post.. i have rbr20 & 7700. Just curious what the performance hit would be, when combined, compared to rbs20/rbr20. Thanks for your time
- plemansAug 01, 2022Guru - Experienced User
I've never tested the performance difference from using the official rbs20 satellite to using the ex7700.
The have the same width backhaul/fronthaul so if you're only using 1, it shouldn't be a whole lot.
