CarlM1975
Feb 01, 2022Initiate
Compatibility of satellites with Orbi RBR20 Router
Hi I have a RBR20 Router and 2 RBS20 satellites, I want to purchase another satellite but Im having difficulty finding one anywhere. Can I buy and use another satellite, for example RBS50? Does ...
Feb 01, 2022Guru - Experienced User
Compatible satellites:
RBS20
RBW30
RBS40
RBS40V
RBS50
RBS50Y
You can also use the EX7500, EX7700, EX8000 but they don't "integrate" with the system but function as their own mesh.
gupshup
Jul 30, 2022Aspirant
Thanks for the post.. i have rbr20 & 7700. Just curious what the performance hit would be, when combined, compared to rbs20/rbr20. Thanks for your time
- plemansAug 01, 2022Guru - Experienced User
I've never tested the performance difference from using the official rbs20 satellite to using the ex7700.
The have the same width backhaul/fronthaul so if you're only using 1, it shouldn't be a whole lot.
