CarlM1975
Feb 01, 2022Initiate
Compatibility of satellites with Orbi RBR20 Router
Hi I have a RBR20 Router and 2 RBS20 satellites, I want to purchase another satellite but Im having difficulty finding one anywhere. Can I buy and use another satellite, for example RBS50? Does ...
gupshup
Jul 30, 2022Aspirant
Thanks for the post.. i have rbr20 & 7700. Just curious what the performance hit would be, when combined, compared to rbs20/rbr20. Thanks for your time
Aug 01, 2022Guru - Experienced User
I've never tested the performance difference from using the official rbs20 satellite to using the ex7700.
The have the same width backhaul/fronthaul so if you're only using 1, it shouldn't be a whole lot.
