Retired_Member
Jul 24, 2019Compatibility Question
I moved into my brother's house recently. He has an tri-band Orbi BRB30 Router with a plug-in satellie unit (Maybe a RBK30). My question is this - I have an orbi RBS40V (Alexa Smart Speaker + Satelli...
Jul 24, 2019Guru - Experienced User
Yes.
Retired_Member
Jul 24, 2019Cool, so to confirm - an AC3000 satellite can connect to an AC2200 network?
- CrimpOnJul 24, 2019Guru - Experienced User
Yes, it can. WiFi systems are "backward compatible." When it connects to the AC2200, it will operate at that lower speed.
