agolem12
Jul 24, 2022Initiate
Compatibility with Orbi RBS20 and RBR40
Hello, I have an Orbi RBS20 and RBR40 system in my house with an Arris modem. Spectrum just upgraded me to a plan that has internet speeds of 500mpbs, but is telling me that my modem cannot hand...
Jul 25, 2022Guru - Experienced User
1. what actual modem do you have? I've gotten that notice before on a device fully capable of handling the speeds I was upgrading to.
2. The Orbi system can handle those speeds wired and wireless. You won't max out the 500mbps over wireless but if you have a decent device that you're testing on and are close to the orbi, you should get close. Its more a limitation of the wireless AC and device you're testing on. Because of wireless overhead, interference, obstruction, etc, wireless won't hit the same speeds as a wired device but you should still be fine.
- agolem12Jul 25, 2022Initiate
I have an Arris SB6190, currently. Spectrum is telling me that my model cannot handle the new upgrade speed of 500 mpbs. I tested my system internet speeds and can get upward of 275. I am just trying to figure out if I need to upgrade my Orbi system for these new speeds, my modem, or both, OR if Spectrum is trying to rope me into renting their equipment.
Thank you!
- plemansJul 25, 2022Guru - Experienced User
The orbi should do fine.
I'd take a look through the smallnetbuilder testing on it. You have to keep in mind that you won't hit those same speeds because they're tested in a controlled environment but the 40 series is a pretty solid system.
Wi-Fi System Roundup - SmallNetBuilder
And it looks like spectrum has the SB6190 approved up to their 400mbps tier according to their website.
Authorized Modems to Use on the Spectrum Network | Spectrum Support
So not sure if its worth upgrading for you or not. Basicallly comes down to if you need the extra speed you might bet from upgrading to a better AX mesh system.
