agolem12
Jul 24, 2022Initiate
Compatibility with Orbi RBS20 and RBR40
Hello, I have an Orbi RBS20 and RBR40 system in my house with an Arris modem. Spectrum just upgraded me to a plan that has internet speeds of 500mpbs, but is telling me that my modem cannot hand...
Jul 25, 2022Guru - Experienced User
1. what actual modem do you have? I've gotten that notice before on a device fully capable of handling the speeds I was upgrading to.
2. The Orbi system can handle those speeds wired and wireless. You won't max out the 500mbps over wireless but if you have a decent device that you're testing on and are close to the orbi, you should get close. Its more a limitation of the wireless AC and device you're testing on. Because of wireless overhead, interference, obstruction, etc, wireless won't hit the same speeds as a wired device but you should still be fine.
agolem12
Jul 25, 2022Initiate
I have an Arris SB6190, currently. Spectrum is telling me that my model cannot handle the new upgrade speed of 500 mpbs. I tested my system internet speeds and can get upward of 275. I am just trying to figure out if I need to upgrade my Orbi system for these new speeds, my modem, or both, OR if Spectrum is trying to rope me into renting their equipment.
Thank you!
