agolem12
Jul 24, 2022Initiate
Compatibility with Orbi RBS20 and RBR40
Hello, I have an Orbi RBS20 and RBR40 system in my house with an Arris modem. Spectrum just upgraded me to a plan that has internet speeds of 500mpbs, but is telling me that my modem cannot hand...
agolem12
Jul 25, 2022Initiate
I have an Arris SB6190, currently. Spectrum is telling me that my model cannot handle the new upgrade speed of 500 mpbs. I tested my system internet speeds and can get upward of 275. I am just trying to figure out if I need to upgrade my Orbi system for these new speeds, my modem, or both, OR if Spectrum is trying to rope me into renting their equipment.
Thank you!
Jul 25, 2022Guru - Experienced User
The orbi should do fine.
I'd take a look through the smallnetbuilder testing on it. You have to keep in mind that you won't hit those same speeds because they're tested in a controlled environment but the 40 series is a pretty solid system.
Wi-Fi System Roundup - SmallNetBuilder
And it looks like spectrum has the SB6190 approved up to their 400mbps tier according to their website.
Authorized Modems to Use on the Spectrum Network | Spectrum Support
So not sure if its worth upgrading for you or not. Basicallly comes down to if you need the extra speed you might bet from upgrading to a better AX mesh system.
