Becky2020
Aug 15, 2020Follower
Compatible Modem for Orbi Router RBR20
I have been told that the issues I am having are due to the fact that I do not have a compatible modem to my Orbi Router RBR20. Does anyone have a list of compatible modems? I cannot find one anywh...
Aug 15, 2020Guru - Experienced User
Most DSL or cable modems are compatible with Orbi.
Some modems have built in routers, if so, This would be a double NAT (two router) condition which isn't recommended. Single function modem is recommended for use with Orbi systems.
https://kb.netgear.com/30186/What-is-Double-NAT
https://community.netgear.com/t5/Cable-Modems-Routers/What-s-the-Difference-Between-a-Cable-Modem-and-Cable-Modem/m-p/1864698#M21950
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-Mode
