Profaniter
Jun 28, 2018Tutor
Compatible Question
I have the RBK50 plus satellite system, it's been so good to me, have not experience any speed drop.
So now with the cable/modem Orbi is out, I was wondering if anyone knew if this is compatible with the ones I have right now? will it work?
if so, how do I pair it up with my RBK50 plus satellite?
Thank you fellows!
1 Reply
I believe you can however the 40 series runs 866Mb on wireless where the 50 series runs 1700Mb on wireless. This would be the main differences.
