DerekFinn
Dec 06, 2021Follower
Compatible satellites for a RBR 20 system
I need to add another satalite to my RBR20 and RBS20 system. the RBS20 has been discontinued do any of the new satalies connect? Thanks
- Dec 06, 2021
The original Orbi satellites will sync with the RBR20 router, including:
RBS50
RBS40
RB30W
RBS20
RBS40V
RBS50Y
Satellites from other product lines will not sync with the RBR20.
(not Obi 'Pro', not Orbi AX, not the '10' series)
People often turn to eBay in this situation.
CrimpOn
Dec 06, 2021Guru - Experienced User
RBS50
RBS40
RB30W
RBS20
RBS40V
RBS50Y
Dec 07, 2021Guru - Experienced User
RBS40v(oice)
Also EX7500, EX7700 will do as alternative extenders for Orbi.
