ClassicalDig
Dec 12, 2017Guide
Computer disconnects for a minute evero 10-15 minutes
This problem has been happening for a while and I can't seem to find a way to fix it, every 10-15 minutes my computer disconnects from the internet, no other devices in my house do this it's only my ...
st_shaw
Dec 12, 2017Master
ClassicalDig wrote:
Tried to find stuff about DHCP IP lease but Netgear doesn't do that
See Reserve an IP Address on page 72 of the user manual here:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Sounds like either you have an issue with your computer's network card or you have an issue with your satellite-to-router backhaul connectivity.
- ClassicalDigDec 12, 2017Guide
That didn't work :/
- st_shawDec 12, 2017Master
I would try deleting your computer's network connection and adding it back in. I'm not really sure how to do that, because I don't know what type of computer you have. You should also make sure you have the latest device drivers for the computer's ethernet card. I would also try moving the satellite and router so they are closer and/or have fewer walls between them, even if temporarily, to see if that removes the disconnects.
- ClassicalDigDec 13, 2017Guide
Huge problem occurred, I uninstalled and reinstalled the Ethernet adapter and when I restarted my computer it says that the connection is limited and I can't sign because it is saying "your device is offline. Please sign in with the last password used in this devicd" I have only ever had one password.
Do I can't get into my computer to fix the limited internet problem and I can't fix the limited internet problem by getting into my computer.
