ClassicalDig
Dec 12, 2017Guide
Computer disconnects for a minute evero 10-15 minutes
This problem has been happening for a while and I can't seem to find a way to fix it, every 10-15 minutes my computer disconnects from the internet, no other devices in my house do this it's only my ...
st_shaw
Dec 12, 2017Master
ClassicalDig wrote:
Tried to find stuff about DHCP IP lease but Netgear doesn't do that
See Reserve an IP Address on page 72 of the user manual here:
http://www.downloads.netgear.com/files/GDC/RBK50/Orbi_UM_EN.pdf
Sounds like either you have an issue with your computer's network card or you have an issue with your satellite-to-router backhaul connectivity.
ClassicalDig
Dec 12, 2017Guide
That didn't work :/
- st_shawDec 12, 2017Master
I would try deleting your computer's network connection and adding it back in. I'm not really sure how to do that, because I don't know what type of computer you have. You should also make sure you have the latest device drivers for the computer's ethernet card. I would also try moving the satellite and router so they are closer and/or have fewer walls between them, even if temporarily, to see if that removes the disconnects.
- ClassicalDigDec 13, 2017Guide
Huge problem occurred, I uninstalled and reinstalled the Ethernet adapter and when I restarted my computer it says that the connection is limited and I can't sign because it is saying "your device is offline. Please sign in with the last password used in this devicd" I have only ever had one password.
Do I can't get into my computer to fix the limited internet problem and I can't fix the limited internet problem by getting into my computer.
- st_shawDec 13, 2017Master
That sounds annoying. Stupid Microsoft.
Does your computer have WiFi? If so, you could try to enable WFi then log back in as normal.
If no WiFi, you probably need to follow the steps at this link to disassociate your computer from your microsoft account. You can add it back later.
http://www.thewindowsclub.com/your-pc-is-offline-windows
