MrMediaGuy
Mar 25, 2019Guide
"Config sync" loop with firmware V2.3.1.44
RBR50 and my two satellites (RBS50 + RBW30) were very stable out of the box for a couple of months now after getting the initial configuration right. However after updating (involuntarily!) to the "a...
SW_
Mar 26, 2019Prodigy
Yeah, v210 has been solid for me as well.
If you haven't already, try these options and see if it works out for you.
1. Disable 20/40 MHz Coexistence
4. Enable Implicit BEAMFORMING - Boosts WiFi speed, reliability, & range for all mobile devices
SW_
Mar 26, 2019Prodigy
MrMediaGuy wrote:
>> ... my two older-gen iPads went from getting about 50Mbps on Speedtest down to about 3Mbps ...
Just in case, verrify that these devices connected to the expected Satellites and not the main Orbi Router. They could be connected to the main Router via 2.4GHz when your Satellites are being offlined/reboot. It will take a while for them to be redirected to the nearest Satellites again. Before you run SpeedTest, disable/re-enable WiFi on the target device so that it can connect to the Satellite.
