MrMediaGuy
Mar 25, 2019Guide
"Config sync" loop with firmware V2.3.1.44
RBR50 and my two satellites (RBS50 + RBW30) were very stable out of the box for a couple of months now after getting the initial configuration right. However after updating (involuntarily!) to the "a...
Deguara1
Apr 06, 2019Aspirant
Hi,
I've just had the exact same problem as you were having, but I think I've found the solution.
If you have a read of this, https://kb.netgear.com/000060756/RBR50-RBS50-Firmware-Version-2-3-1-44 it states that if you CANNOT update the firmware straight from V2.2.1.210 to V2.3.1.44, you must first update to V2.2.1.212 using the manual update option.
I have done this and all seems to be fine again so far, but it's early days and I've only had it installed for approx 20 mins.
I hope this helps you as it seems to have worked for me.
Kind regards,
Kevin.
