Zekkjace
Mar 05, 2020Aspirant
Config sync on RBS50
I recently changed providers from Spectrum to AT&T. In my time with Charter, my Orbi worked perfectly the entire time because I used their modem but not their router. Pretty simple set up. After I swi...
tooo_many_shoes
Mar 30, 2020Guide
Ok well let me explain a little further. The reason I was wanting the Orbi router to assign the IP addresses is that it is probably more current technology (i.e. faster/overall better) than the AT&T provided Arris BGW210-700..maybe? I found documentation online suggesting that. Your opinion? Or what other options are available? Thanks
Mar 30, 2020Guru - Experienced User
Yes having the Orbi router in router mode would be perferred over the ISP modem. IF you want to configure the RBR for router modem then use IP Passthru on the Modem for the RBR. When the RBR is in AP mode, do not use IP Pass thru on the modem for this configuration.
tooo_many_shoes wrote:Ok well let me explain a little further. The reason I was wanting the Orbi router to assign the IP addresses is that it is probably more current technology (i.e. faster/overall better) than the AT&T provided Arris BGW210-700..maybe? I found documentation online suggesting that. Your opinion? Or what other options are available? Thanks
- tooo_many_shoesApr 04, 2020Guide
Received my replacement satellite from NG yesterday. I received an updated version of the satellite - an RBS50v2. Changed the config on the Orbi Router to router mode per your suggestion...and everything is working just fine. Thank you so much!!
- FURRYe38Apr 04, 2020Guru - Experienced User
Glad it's working well for you now.
Enjoy. :smileywink:
tooo_many_shoes wrote:Received my replacement satellite from NG yesterday. I received an updated version of the satellite - an RBS50v2. Changed the config on the Orbi Router to router mode per your suggestion...and everything is working just fine. Thank you so much!!
