RV078
Jan 21, 2019Aspirant
configure Hitron CODA 4582U bridge mode with ORBI
Hi there
I'm attempting to configure my 4582U to use my ORBI as an access point.
However, when I turn off the residential gateway on my 4582U (to stop wifi broadcasting), the ORBI no longer picks...
Jan 22, 2019Guru - Experienced User
If your bridging and disabling the ISP modem gateway, then leave the Orbi router in Router mode, no need to change to AP modem.
AP mode is if you leave the ISP modem in Router mode, then you can change the Orbi to AP mode.
Modem Combo Units:
Couple of options,
1. Configure the modem for transparent bridge mode. Then use the Orbi router in router mode. You'll need to contact the ISP for help and information in regards to the modem being bridged correctly. Orbi would be in router mode here.
2. If you can't bridge the modem, disable ALL wifi radios on the modem, configure the modems DMZ for the IP address the Orbi router gets from the modem. Then you can use the Orbi router in Router mode.
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. ISP modem would be in router mode here. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
RV078 wrote:
Hi there
However, when I turn off the residential gateway on my 4582U (to stop wifi broadcasting), the ORBI no longer picks up the internet (even though if I directly connect the ethernet cable into my computer it works well).
Maybe I'm using the wrong port on the 4582?
Do I have to change the orbi to an access point?
THanks in advance
Kumar
