RV078
Jan 21, 2019Aspirant
configure Hitron CODA 4582U bridge mode with ORBI
Hi there
I'm attempting to configure my 4582U to use my ORBI as an access point.
However, when I turn off the residential gateway on my 4582U (to stop wifi broadcasting), the ORBI no longer picks...
Jan 28, 2019Guru - Experienced User
Any progress on this? Just checking...
RV078 wrote:
Hi there
However, when I turn off the residential gateway on my 4582U (to stop wifi broadcasting), the ORBI no longer picks up the internet (even though if I directly connect the ethernet cable into my computer it works well).
Maybe I'm using the wrong port on the 4582?
Do I have to change the orbi to an access point?
THanks in advance
Kumar
