Dmirabelli
Oct 19, 2020Tutor
Configure Orbi RBR20 on my Orange Fiber in Spain
Hi there, I'm facing issues to configure the Orbi RBR20 in my fiber network. Basically I have a ONT connected to a router and I want to replace the Orange router with the Orbi. Actually I tried t...
- Oct 19, 2020
Unsure there is PPPoE in the play...
According to several resources, Orange Spain is plain IP with DHCP on VLAN 832 tagged WAN when it's a direct line. If it is NEBA - this is when Orange doesn't have a direct line to your area - it's VLAN 20 tagged.
Dmirabelli
Oct 19, 2020Tutor
Through the 192.168.1.1 I try using the advanced Setup Wizard, providing the MAC address of the previous router. After that it takes time to load the internet confit but at the end it always says “Problem Detecting the Internet Connection”.
- schumakuOct 19, 2020Guru - Experienced User
- DmirabelliOct 19, 2020Tutor
Hi schumakuand thank you for your reply!
Actually I thinkg I don't have plain IP, most likely it's a NEBA as you said. Having said that, should I change the 832 VLAN for a 20 VLAN config? Same priority in this case?
Hi schumaku , just to let you know I finally did it. Thanks also to your input, it was NOT VLAN 832 priority 0, for NEBA it's 20 0 for all the devices. Olso I was trying to manually configure the DNS, since I moved to automatic it's now working!
Thanks again! Appreciated!
