Dmirabelli
Oct 19, 2020Tutor
Configure Orbi RBR20 on my Orange Fiber in Spain
Hi there, I'm facing issues to configure the Orbi RBR20 in my fiber network. Basically I have a ONT connected to a router and I want to replace the Orange router with the Orbi. Actually I tried t...
- Oct 19, 2020
Unsure there is PPPoE in the play...
According to several resources, Orange Spain is plain IP with DHCP on VLAN 832 tagged WAN when it's a direct line. If it is NEBA - this is when Orange doesn't have a direct line to your area - it's VLAN 20 tagged.
Dmirabelli
Oct 19, 2020Tutor
Through the 192.168.1.1 I try using the advanced Setup Wizard, providing the MAC address of the previous router. After that it takes time to load the internet confit but at the end it always says “Problem Detecting the Internet Connection”.
schumaku
Oct 19, 2020Guru - Experienced User
