Dmirabelli
Oct 19, 2020Tutor
Configure Orbi RBR20 on my Orange Fiber in Spain
Hi there, I'm facing issues to configure the Orbi RBR20 in my fiber network. Basically I have a ONT connected to a router and I want to replace the Orange router with the Orbi. Actually I tried t...
- Oct 19, 2020
Unsure there is PPPoE in the play...
According to several resources, Orange Spain is plain IP with DHCP on VLAN 832 tagged WAN when it's a direct line. If it is NEBA - this is when Orange doesn't have a direct line to your area - it's VLAN 20 tagged.
schumaku
Oct 19, 2020Guru - Experienced User
Dmirabelli
Oct 19, 2020Tutor
Hi schumakuand thank you for your reply!
Actually I thinkg I don't have plain IP, most likely it's a NEBA as you said. Having said that, should I change the 832 VLAN for a 20 VLAN config? Same priority in this case?
