ElCapo
May 01, 2021Luminary
Configure RBR50 to work with Virgin Media Modem Mode Hub
Hi I am about to change my internet supplier from ADSL to VirginMedia Cable. My current set up is a RBR50 Orbi Router in Router Mode connected to a Netgear DM200-100EUS DSL Modem. When I con...
- May 07, 2021
Hi
Just wanted to post a conclusion to this topic.
As advised, there is no login required for Orbi to Virgin Media Hub4. Simply switch to modem mode on the Virgin Hub, select "ISP does NOT need a login" on the Netgear Orbi. Then connected the two devices. I used port 4 on the Virgin Media Hub
Thanks All
May 02, 2021Guru - Experienced User
seems like i've seen quite a few posts on here about virgin media's "modem only" mode not working properly.
some have had to leave the virgin media device in router mode, disable its wifi, and run the orbi in access point mode.
Not saying it won't work for you though.
