ElCapo
May 02, 2021Luminary
Configure RBR50 to work with Virgin Media Modem Mode Hub
Hi I am about to change my internet supplier from ADSL to VirginMedia Cable. My current set up is a RBR50 Orbi Router in Router Mode connected to a Netgear DM200-100EUS DSL Modem. When I con...
- May 08, 2021
Hi
Just wanted to post a conclusion to this topic.
As advised, there is no login required for Orbi to Virgin Media Hub4. Simply switch to modem mode on the Virgin Hub, select "ISP does NOT need a login" on the Netgear Orbi. Then connected the two devices. I used port 4 on the Virgin Media Hub
Thanks All
May 02, 2021Guru - Experienced User
Also ask the ISP what settings and configurations are needed as well. The DM series modem has a built in router as well. Something to refer to the uer manual or the NG DSL modem forum for additional help and information.
ElCapo
May 08, 2021Luminary
Hi
Thanks All
- FURRYe38May 08, 2021Guru - Experienced User
Enjoy. :smileywink:
