JamesRubin
Jun 26, 2021Follower
Configure Sync
This is about adding an RBS50 to my RBR50 router. It's the 4th satellite. It appears to be connected but in the Backhaul status column, instead of "Good" to describe the connection, it says Config Sy...
Jun 27, 2021Guru - Experienced User
Does the RBS have the same version of FW loaded as whats on the RBR? Needs to be the same version.
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
