PhysicsWorld
Oct 26, 2022Guide
Configuring a new Orbi RBR50 as an AP when connected to an existing RBR50 router
Greetings: I am trying to add a new RBR50 (to extend the coverage to my backyard) to an existing RBR50 router with 3 satellites. I understand that the new RBR50 router has to be configured in AP...
michaelkenward
Oct 27, 2022Guru - Experienced User
PhysicsWorld wrote:
Greetings:
I am trying to add a new RBR50 (to extend the coverage to my backyard) to an existing RBR50 router with 3 satellites. I understand that the new RBR50 router has to be configured in AP mode.
I find that the easiest way to do this is with the second router plugged into a PC that is not connected to the network.
Then just use the usual login process.
Put the router into AP mode, then take the network through the usual reboot sequence.
You might also be able to get at the second Orbi through its wifi SSID and IP address.
