Pfredd
Sep 30, 2019Guide
Configuring IOT devices
Many IOT devices, such as Wi-Fi Outlets, Door Bell Cameras, etc., need you phone to be connected to the 2.4GHZ band of your router in order for the device's app to perform initial device configuratio...
Pfredd
Oct 01, 2019Guide
Once I reduced the 5GHZ power, I moved to a bathroom that was only 20 feet away from the ORBI. I shut the door and reconnected to WI-Fi and my phone connected to the 2.4GHZ band...
- FURRYe38Oct 01, 2019Guru - Experienced User
To get IoT devices connected during there initial setup, you can also temporarily disable the 5Ghz SSID broadcast as well under Advanced Tab/Advanced Settings/Wireless Settings. After you get the 2.4Ghz devices setup, re-enable the 5G SSID broadcast.
Pfredd wrote:Once I reduced the 5GHZ power, I moved to a bathroom that was only 20 feet away from the ORBI. I shut the door and reconnected to WI-Fi and my phone connected to the 2.4GHZ band...
- AnonymousOct 01, 2019
FURRYe38 wrote:To get IoT devices connected during there initial setup, you can also temporarily disable the 5Ghz SSID broadcast as well under Advanced Tab/Advanced Settings/Wireless Settings. After you get the 2.4Ghz devices setup, re-enable the 5G SSID broadcast.
Some users have said this is NOT true or available
Its available. Has been there for a while now.
