Pfredd
Sep 30, 2019Guide
Configuring IOT devices
Many IOT devices, such as Wi-Fi Outlets, Door Bell Cameras, etc., need you phone to be connected to the 2.4GHZ band of your router in order for the device's app to perform initial device configuratio...
Oct 02, 2019Guru - Experienced User
Its available. Has been there for a while now.
MarcusVR
Oct 02, 2019Tutor
I just went to the web interface and, in Advaced tab, Advanced Setup, Wireless Settings, I deselected "Enable SSID Broadcast" to the 5 GHz band. It allowed me to pair the problematic devices! Restore this option after the devices were paired didn't affected its connection.
- FURRYe38Oct 02, 2019Guru - Experienced User
Glad that worked for you. Works for others as well. :smileywink:
Enjoy.
MarcusVR wrote:I just went to the web interface and, in Advaced tab, Advanced Setup, Wireless Settings, I deselected "Enable SSID Broadcast" to the 5 GHz band. It allowed me to pair the problematic devices! Restore this option after the devices were paired didn't affected its connection.
