6old3nra1n
Nov 01, 2020Tutor
Configuring ORBI RBR50 with ATT Fiber
Hello all, I've been a long time user of my Orbi RBR50 first with an Xfinity cable connection. It has been rock solid (occasional outages but nothing significantly long in duration). The impressi...
Nov 02, 2020Guru - Experienced User
Something to ask your ISP about. ISP have the tech info on there modems and hardware...
gr8sho
Nov 03, 2020Virtuoso
You can’t turn off router function in the BGW210. Best to use the Orbi in AP mode. It’s how mine is setup. Only change I make to a factory reset gateway is to disable the wireless radios.
