sheepboy
Aug 15, 2018Aspirant
Configuring the Orbi RBR20 via a webpage?
I got Orbi because of its built in Parental control, Circle. When I first set it up all was good for about a day, then…. Never had issues with my old Wi-Fi setup other than not having Parental Controls.
Issue: Network keeps dropping connection, can’t access services outside the Orbi network. This seems to happen multiple times a day/hour. The other night it was every 20min. wired network has no issues (see setup below).
Steps taken:
- Hardwired Satellites to base station. – no help
- Turned off Parental controls (Circle) – helped but still get drop out every day.
Workaround…reboot Orbi
Setup...
Cable modem -> PC based firewall (Sophos UTM)-> Gig switch (Wired network) -> Orbi wan port
Have 10+ wifi devices on line at all times, when everyone is home it can go over 15+.
ROUTER INFORMATION
Hardware Version |
RBR20 |
Firmware Version |
V2.1.4.16 |
GUI Language Version |
V1.0.0.325 |
Operation Mode |
Router |
LAN Port |
MAC Address |
CC:40:D0:5B:DF:A8 |
IP Address |
192.168.1.1 |
DHCP Server |
On |
Device Name |
Current Version |
Router |
RBR20 |
RBR20 |
V2.1.4.16 |
Satellite |
RBS20 |
Orbi Satellite-1 bed |
V2.1.4.16 |
Satellite |
RBS20 |
Orbi Satellite-2 office |
V2.1.4.16 |
IP Address |
192.168.xxx.61 |
Subnet Mask |
255.255.255.0 |
Default Gateway |
192.168.xxx.44 |
DHCP Server |
192.168.xxx.44 |
DNS Server |
192.168.xxx.44 |
Lease Obtained |
0 Days, 7 Hours, 20 Minutes |
Lease Expires |
0 Days, 6 Hours, 1 Minutes |
Any help would be appreciated.
- FURRYe38Guru - Experienced UserWhat is the Mfr and model# of the IP modem?What is the size of your home? Sq Ft?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.What is the Mfr and model# of the switch? Managed or Non Managed?Try this Setup...
Cable modem -> Orbi wan port
Is the Orbi in Router mode or AP mode?
- sheepboyAspirant
Update...Just had My phone have no internet access, in this case for testing I turned on Parental controls (Circle). As soon as I hit save all was good with my device. Prior to this edit of settings, the kid’s wireless devices were working. Were all 12 "online" devices working, can’t say for sure but know 3 were working. Last night I know it was my phone and at least 2 other devices with this issue. My phone at this time and last night was connected to the router not a satellite.
FURRYe38 to Answer your questions…
What is the Mfr and model# of the IP modem? Model Name: SB6141 Vendor Name: ARRIS Group, Inc.(surfboard)
What is the size of your home? 5 bed 2 story Sq Ft? 3,122 sqft
What is the distance between the router and satellite(s)? 35+ they are Hardwired to each other.What is the Mfr and model# of the switch? Netgear gs116 Non Managed
Try this Setup...
Cable modem -> Orbi wan port -- my wired devices are not have connection issues, which is one network up from the Orbi. Prior to installing Orbi that now up stream network was handling ALL network traffic as the wireless hardware (3) was in AP mode, with no issues.
Is the Orbi in Router mode or AP mode? Router Mode, the whole reason I got this was for parental controls, in AP mode you have none.
I have a feeling that my particular Orbi Router is just too small for my network. As soon as you change a setting everything is good, almost like it resets the used memory and is now free to handle the load again.
Having a Firewall before router maybe a cause as well. When in router mode, the Orbi already had a built in firewall.
Try testing with out the Firewall between the modem and Orbi router.
Also try this:
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
MIMO, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
