jpain3
Feb 24, 2021Tutor
Confirmation that Netgear Routers cannot forward DNS queries to a specific IP
From what I can tell after extensive googling and searching these forums, Netgear routers of any model or configuration DO NOT have the ability to do basic, simple, standard, functions related to for...
CrimpOn
Feb 24, 2021Guru - Experienced User
How about using the "Block Services" feature on the Security menu?
Block all IP's from Port 53 TCP/UDP
