glennelliott
Apr 15, 2018Initiate
Conflict between Orbi and Bang & Olufsen WISA speakers
I've had the Orbi RBK50 and RBS40 Satellite system for about 3 weeks now and the wifi quality is excellent and setup was great. However I have one problem. Since I installed the Orbi, the Subwoof...
st_shaw
Apr 15, 2018Master
Try it with the Orib and the B&O speakers as far apart from each other as possible. Use a long Ethernet cable if you need to. Even if they are on separate frequencies they could stil interfere if they are too close together.
