anengineer
Jan 05, 2019Aspirant
Conflict between Orbi and digital TV antenna
I have found interferrence between Orbi and my digital TV antenna. If the Orbi Satellite is too close to the TV, the tuner is stuck on one channel, with audio & video going in and out - and I have lo...
- Jan 05, 2019
Yes, you should keep Orbi away from other RF devices. They can interfere, even if the devices use different frequencies.
The satellite is turning amber because the signal became poor. The RF singl-to-noise ratio will vary over time, so this is not unusual. It also means if the satellite turned blue once it doesn't mean everything is good. You need a signal strong enough such that it's still good, even when the signal varies on the low side.
If the TV antenna is the issue, you should also have the option of moving the antenna farther away from the TV and Orbi, by using a longer length of coax cable to attach the antenna to the TV.
anengineer
Jan 08, 2019Aspirant
I have moved the Orbi Satellite away from the TV/antenna. It is now about 25 ft from the TV and about 55 feet from the Orbi Router. The interference with the antenna is gone, and the Internet connection in the area between the TV and Satellite is consistently good (there is a wall between the TV and the Satellite.) Since the iPad is working well in this same area, it no longer is a suspect in it having dropped connection often.
I perhaps had fallen for the marketing pitch from Netgear in that they say the RKB22 is good for a house up to 4000 sq. feet. Our house is two-story and 3000 sq. feet. But its footprint is about 75 feet long; so it is not the average 3000 sq foot house.
I switched from a Netgear R6300/EX6200 setup to Orbi. Both the R6300 and EX6200 used 2.4 GHz and 5 GHz, which resulted in 4 network connections. It was a bit tedious when roaming from room to room because of the delay in the device switching to the closer router, and each connection had its own name to consider if one manually switched. The Orbi has one name; so roaming rome room to room is much simpler.
st_shaw
Jan 08, 2019Master
Good to hear you got it working. Thanks for letting us know.
