6old3nra1n
Nov 02, 2020Tutor
Conflicting IP shown for devices connected to Orbi satellite
I recently made the switch to ATT "gigabit" fiber and the WiFi speeds are not only worse than my previous half megabit Xfinity connection, they are also more erratic despite using the same Orbi RBR50...
Nov 02, 2020Guru - Experienced User
It makes me suspect that your arris isn't running passthrough/bridge mode properly.
Have you tried putting the arris back in router mode (disabled its wireless) and then the orbi in AP mode?
6old3nra1n
Nov 02, 2020Tutor
I haven’t gotten to this point. I followed the same instructions which has often been discussed on this forum to set things up and I was able to get online so I didn’t think much of anything not working per se. But now it seems there are some other downstream issues that are present. Nothing critical (except for speed issues) in terms of errors..
