Semerdj
Sep 17, 2018Follower
Conncection problem with devices on my Orbi Tri-band
I have installed my Orbi Tri-band. I am now having an issue connecting my devices. Tablets (ipad, android tab), phones (Samsung 8), roku, direct tv are all working great. I am having an issue with...
Sep 18, 2018Guru - Experienced User
What FW is currently loaded?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials.
Might try this, temporarily set WPA security on the Orbi router to Disable or OPEN. Then try to connect one of the problem devices to the routers wifi. Does it connect then does it get internet?Then try WPA and TPIK, then try WPA2 and AES only.
MIMO, Daisy Chain, Fast Roaming, IPv6. Save settings and reboot the router and satellite(s).
