alivelarde
Feb 18, 2020Aspirant
Connect 1st Orbi satellite via Ethernet to router then connect 2nd satellite wirelessly to 1st sat
My router is located on the second level, my satellite is on the first floor (where my office is) but there are too many turns and walls to get there so reception is terrible. I added a second satel...
Feb 19, 2020Guru - Experienced User
alivelarde wrote:My router is located on the second level, my satellite is on the first floor (where my office is) but there are too many turns and walls to get there so reception is terrible.
I added a second satellite "half way" but although it improved slightly, it is still pretty slow compared to the speed on the second floor.
My question:
Could I use an ethernet cable to connect my router to the"half way" 1st satellite and then connect wirelessly my 2nd satellite (in the office) to the 1st satellite using a daisy chain topology? Since they are much closer and there are not that many turns/walls between both satellites my hope is that the connection would improve. Any help would be greately appreciated.
If you wonder why I don't just just try it out and see if it works, the answer is because I would have to drill through a few walls just to see if it works.
Thanks,
Alejandro
- alivelardeFeb 19, 2020AspirantThe distance may be a little over 30 ft but the layout of the house seem to be the problem. Too many walls between the router and the location of the 1st satellite and unfortunately there is not a closer place to place it.
- FURRYe38Feb 19, 2020Guru - Experienced User
Ok, just making sure. Hopefully the LAN cable and wireless RBS will help get it working better. Building materials will impact signal. Nature of the beast. :smileywink:
- alivelardeFeb 19, 2020AspirantThank you again!!!
