TXFarmer
Jun 13, 2019Follower
Connect 2 outdoor units to make a big mesh network?
We have 2 structures about 660 feet apart. One of them (Structure 1) currently has our inbound internet connection. The other structure (Structure 2) has power, and I'd like to find the easiest way t...
CrimpOn
Jun 13, 2019Guru - Experienced User
My guess is, "not likely." I would check out the Ubiquiti line. They have units at a fraction of the cost of the RBY50 that are designed specifically for creating a point-to-point link. Several forum participants have posted about using Ubiquiti units to extend Orbi coverage. 660 ft. is a long diostance for 802.11 WiFi.
- plemansJun 13, 2019Guru - Experienced User
agree with CrimpOn 660ft is a long distance. Running ethernet is only good for 100m without a booster/switch in line. If you got daisy chaining to work that far, you'll have issues with latency and errors would be my bet. I've never tried to reach that far but I've had issues trying to use wireless over a 200ft range with consumer gear. Especially for the speeds you want.
