Laers74
Jan 22, 2020Follower
Connect certain devices only to certain sattelite
Hi all, Is there a way to keep certain device only connected to a certain sattelite? No, whenever there is a short outage of one of the sattelites, my wireless speakers (BlueSound) connect to an...
Jan 22, 2020Guru - Experienced User
30 feet is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected. https://kb.netgear.com/000036466/How-far-should-I-place-my-Orbi-satellite-from-my-Orbi-router
You can adjust the power output of the RBRs wifi radios as well. Under Advanced Tab/Advanced Settings/Wireless Settings
Try setting manual channel 1, 6 or 11 on 2.4Ghz and any unused channel on 5Ghz.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
Laers74 wrote:Hi all,
No, whenever there is a short outage of one of the sattelites, my wireless speakers (BlueSound) connect to another sattelite and, when the previous one comes back alive, the do not connect back to the previous one, so the connection is much weaker then before.
Is there a way to register the MAC addresses tot one of the sattelites?
Best regards,
Robbert
