Drewmama
Jun 28, 2019Guide
Connect device to 2.4ghz only
I have a RBK22. My Ring doorbell can only connect to 2.4ghz. My Echo Show can connect to both 2.4 and 5ghz and automatically connects to 5ghz. However I need the Echo Show to connect only to 2.4ghz i...
Will_T
Jun 28, 2019Apprentice
I am running into similar issues. There appears to be no way to turn off 5G. You could try what I have done: In the advanced settings of the router, I have reduced the 5G signal strength to 25%. This means that all the devices see the 2.4G signal as being better than the 5G so they connect via 2.4. I don't mind this as I have found 2.4 to be better than 5G in all circumstances other than being in the same room as the router. Then 5G is better in that situation, but the 2.4G is still plenty good. And in all other situations, like long distances or several walls, floors, or ceilings, the 2.4G is much better. In other words, I never miss or need 5G. It is a workaround though and not a real solution.
I am also concerned, but unsure, that by doing this I have adversly affected the connection between the router and the satellites as that seems to be only 5G. But the backhaul status of the two satellite connections is shown as being "good" even with the 5G signal reduced to 25% so maybe reducing the 5G signal to 25% does not impact the router to satellite connections? Does anyone know the answer to that?
- DrewmamaJun 28, 2019GuideI temporarily stopped broadcasting the 5ghz using the advanced settings and connected my Echo to 2.4 successfully. However, as soon as I turned the 5ghz back on, the Echo automatically connected to the 5ghz. I will try what you suggest about lowering the power down to 25%.
- Will_TJun 28, 2019Apprentice
Drewmama Is this what you did? >> I went to Advance>Wireless> Advanced Wireless Settings (5GHz 802.11a/n/ac) and unchecked both the "Enable SSID Broadcast" and "Enable WMM (Wi-Fi multimedia) settings" boxes. Then clicked "Apply". But the 5G signal was still available and devices still connected to it. I then assumed that stopping the broadcast was not the same as actually turning it off? So that is when I turned the power down to 25%
- DrewmamaJun 28, 2019GuideYes, that is what I did except I didn't uncheck "Enable WMM.."
- Fl1ntstoneJun 28, 2019Apprentice
Hi Guys,
There is a way of splitting the 2.4Ghz and 5Ghz SSIDs:
Good luck :)
- DrewmamaJun 28, 2019GuideThanks, I did see the post you provided but when I got to the end, I thought it said with the latest firmware update, it didn't work? Plus, I don't think I would be comfortable messing around with the settings like that.
