Drewmama
Jun 27, 2019Guide
Connect device to 2.4ghz only
I have a RBK22. My Ring doorbell can only connect to 2.4ghz. My Echo Show can connect to both 2.4 and 5ghz and automatically connects to 5ghz. However I need the Echo Show to connect only to 2.4ghz i...
Fl1ntstone
Jun 27, 2019Apprentice
Hi Guys,
There is a way of splitting the 2.4Ghz and 5Ghz SSIDs:
Good luck :)
Drewmama
Jun 27, 2019Guide
Thanks, I did see the post you provided but when I got to the end, I thought it said with the latest firmware update, it didn't work? Plus, I don't think I would be comfortable messing around with the settings like that.
